31 Jan 2008 at 09:33 #1 Stinky Stinky Soldato Joined 28 Mar 2005 Posts 9,250 Will flashing a W810i remove the passcode from the phone? i have forgotten it as it was an old phone
31 Jan 2008 at 09:50 #2 basmic basmic Permabanned Joined 10 Apr 2004 Posts 13,122 Location Darlington, County Durham Usually 1234 or 1111 - which network you on?
31 Jan 2008 at 10:00 #3 Stinky Stinky Soldato OP Joined 28 Mar 2005 Posts 9,250 its on t mobile. i've tried 1111 1234 2222 3333 etc
31 Jan 2008 at 10:30 #4 bkumar4u bkumar4u Associate Joined 16 Nov 2004 Posts 42 Location london HI, Try 0000 or 12345 Bal
31 Jan 2008 at 12:58 #7 CoreRipOffDuo CoreRipOffDuo Associate Joined 28 Dec 2007 Posts 621 Just ring up the network provider, they should be able to reset it for you.
1 Feb 2008 at 11:22 #8 Stinky Stinky Soldato OP Joined 28 Mar 2005 Posts 9,250 its the pincode to get onto the phone. not a network set one. or am i misunderstanding again lol
1 Feb 2008 at 13:11 #9 CoreRipOffDuo CoreRipOffDuo Associate Joined 28 Dec 2007 Posts 621 Oh, in that case just enter the wrong number 3 times (still is 3 isn't it?), then phone up the network to get your PUC code. Problem solved.
