Completely made up, why would there be more friction when the engine is going the same speed and the wheels are going slower?? and why are you generating more torque when you are traveling slower?B, - my take, even though you are using more fuel to generate more torque in B , the frictional engine losses predominate in A so the fuel used to travel a given distance ends up being greater than travelling in 6th at a higher speed, despite the increase in fuel for aero drag at higher speed
so to travel a mile in 1st @1500 say 2000J friction + 50J aero (driving that mile might take 10minutes?)
6th @1500 50J friction + 1000J aero
we are talking about the frictional energy(engine/transmission) losses during the time is takes to drive a mile (mpg efficiency) not the frictional energy expended over time, which would, indeed, be greater for the 6th gear/1500rpm/faster situation. - #notdissingnewton.Completely made up, why would there be more friction when the engine is going the same speed and the wheels are going slower??
Who is 'we'?we are talking about the frictional energy(engine/transmission) losses during the time is takes to drive a mile (mpg efficiency) not the frictional energy expended over time, which would, indeed, be greater for the 6th gear/1500rpm/faster situation. - #notdissingnewton.
it was budforces question mpg at 1500rpm 1st vs 1500rpm 6th so, related to fuel savingWho is 'we'?
you can't escape from talking about energy used to cover the distance , which relates to mpg, on ev topic people are familiar with talking about Kwhrs of energy, but using those might have conflated topics, so I went with joules, you could use CC's of petrolYet you turn up with some Joules conversation which will be lost on most people.
frictional energy, to cover the mile in 1st is more than 6th 2000>50 ? I don't see the issue.It was you who said more friction in 1st gear to cover a mile! (not time) I quote your post below which i assume you made rather than copy and pasted from somewhere else? unless you are going to argue 50J is more that 2000J?
"so to travel a mile in 1st @1500 say 2000J friction + 50J aero (driving that mile might take 10minutes?)
6th @1500 50J friction + 1000J aero"
NoOk humour me again then.
If you are making a journey that is 60 miles.
If you drive at 60mph the entire way, it'll take you 1 hour.
If you drive at 30mph, it'll take you 2 hours.
Hopefully I am right so far
But your cars engine uses fuel just by running, on the second trip it's running for twice as long, right so far?
I'm not saying you will use twice as much fuel doing the trip at 30mph, but you still need to factor that in? No?
Another way to look at it would be. If me and you have identical cars each filled with exactly 1 gallon of fuel, if I drive at 50 mph which gets me 50 mpg and you travel at 70 which gets you 40mpg what will happen?
You will take off and leave me behind but eventually you will run out of fuel, I will pass you a few minutes later doing the clarkson smug face and will carry on for another 10 miles.
Im seriously amazed that you guys have been driving for how long? and haven't noticed that driving slower on the motorway uses less fuel. Instead we are making up formulas to try and prove physics wrong. Lower engine speed less friction, lower vehicle speed less drag. Engine speed needs to be around optimum BSFC for really optimal but this concept is why idling at 50mph wouldnt work either.
The problem is turning it into actual real world meaningful gains on a larger scale and without other potential unintended side effects.
Dropping all the speed limits indiscriminately by 10 MPH for instance probably won't have the effect it might look like on paper.
Might have a stronger effect insteadDropping all the speed limits indiscriminately by 10 MPH for instance probably won't have the effect it might look like on paper.
unless everyone overthinks the problem
So lowering speed limits will indirectly reduce congestion, which also improves average fuel consumption
