*****G.SKill Ripjaw X Sandybridge approved memory arrives tomorrow!!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right guys for those of you who want official Sandybridge approved memory and some very fast memory indeed we have selected G.Skill's amazing Ripjaw X range of memory. All of these kits are designed and tested to run at just 1.50v:-
G.Skill RipJawX 4GB (2x2GB) DDR3 PC3-17000C9 2133MHz Dual Channel Kit (F3-17000CL9D-4GBXMD) @ £109.99 inc VAT
G.Skill has announced the development of its brand new RipjawsX series memory modules, designed specifically for Intel Sandy Bridge LGA1155 processors, and H67 and P67 motherboard platforms. The new RipjawsX series consists of a complete range of memory solution, from DDR3 1,333MHz, 1,600MHz, 1,866MHz, 2,133MHz, 2,200MHz to 2,300MHz. Combined with the Intel’s highly anticipated Sandy Bridge platform, G.Skill RipjawsX series memory kits deliver more bandwidth and performance than ever.
Building on the strong success of the first generation Ripjaws brand in performance memory kits, every single RipjawsX memory kit is hand-tested on an Intel Sandy Bridge platform in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology!The following list shows the detail specifications of G.Skill RipjawsX family.
Model Name: F3-17000CL9D-4GBXMD
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-10-9-28 2N
Capacity: 4GB (2GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.5V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Warranty: Lifetime
Only £109.99 inc VAT.
ORDER NOW
G.Skill RipJawX 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-8GBXL ) @ £99.98 inc VAT
Model Name: F3-12800CL9D-8GBXL
Main Board: INTEL
System: DESKTOP
System Type: DDR3
CAS Latency: 9-9-9-24 2N
Capacity: 8GB (4GBx2)
Test Voltage: 1.5V
Type: 240-pin DIMM
Warranty: Lifetime
Only £99.98 inc VAT.
ORDER NOW
G.Skill RipJawX 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-4GBXL) @ £49.99 inc VAT
Model Name: F3-12800CL9D-4GBXL
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Test Voltage: 1.5V
Type: 240-pin DIMM
Warranty: Lifetime
Only £49.99 inc VAT.
ORDER NOW
G.Skill RipJawX 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (F3-12800CL7D-4GBXM) @ £59.99 inc VAT
Model Name: F3-12800CL7D-4GBXM
Main Board: INTEL
System: DESKTOP
System Type: DDR3
CAS Latency: 7-8-7-24 2N
Test Voltage: 1.5V
Type: 240-pin DIMM
Warranty: Lifetime
Only £59.99 inc VAT.
ORDER NOW
G.Skill RipJawX 4GB (2x2GB) DDR3 PC3-12800C6 1600MHz Dual Channel Kit (F3-12800CL6D-4GBXH) @ £74.99 inc VAT
Model Name: F3-12800CL6D-4GBXH
Main Board: INTEL
System: DESKTOP
System Type: DDR3
CAS Latency: 6-8-6-24 2N
Test Voltage: 1.5V
Type: 240-pin DIMM
Warranty: Lifetime
Only £74.99 inc VAT.
ORDER NOW
This is excellent memory, but do remember Corsair XMS3, Vengeance and G.Skill Value are all fine with Sandybridge and are better value for money, but for those who wanted another option, well we now have it. :D
Timings on the 2133MHz are good but shame theres no XMP support as some mobos could raise these timings. And could you clarify if 1.5v is at just 1600MHz with states timings?
Its 1.50v for 2133MHz too with this kit. :)
Thanks, that is very good. I guess the new RipjawX are for people looking to get into overclocking with SB. Looks much improved over the standard Ripjaw from 2 years ago.
Plus the standard sized heat-spreaders solves the problem of when you choose certain high-end CPU coolers with the additional 120mm fan, this can mean it won't fit.
Also any news when the faster 8GB kits will arrive, Like the below one: -
[ Ripjaws-X] F3-17000CL9D-8GBXLD
DDR3-2133 PC3 17000 8GB(4GB x 2)
CL 9-11-9-28-2N
1.65 Volts
CL 9-11-9-28-2N
1.65 Volts
Were not doing 1.65v kits sorry.
Whole point of this memory is the 1.50v kits, the 1.65v kits kind of defeat the the idea and the Vengeance 8GB kits are better.
However the 4GB G.Skill kits are supreme, the 6-8-6-24-2N kit runs flawlessy at those timings at its rated 1.50v and it also runs fine at 2133MHz at 9-10-9-28-2N timings as well. Very impressive indeed and good value for money. :)
OcUK now has a very good range of Sandybridge memory that is ideal. :)
Hi there
Got the 6-8-6-24-2N kit running at 1600MHz with 6-7-6-21-1N timings now. :D
Awsome memory! :D
Plus first IN STOCK at OcUK! :)
OCUK Staff:
My G.Skill Ripjaw sticks are faulty and require RMA'ing to yourselves, so instead of being without a computer I will buy some more ram for my i5 750 rig.
Would the 1.50v ram sticks be OK for the old i5? These new sticks say suited to i5 Sandy Bridge etc but no mentioned of the old i5. My Ripjaws were 1.60v.
OCUK Staff:
Yeah the older sticks will work fine with 1156 i5
We can specify a bundle with the C7 Ripjaw if you want. Just send me an email and I can get that sorted for you :)
Thanks you just read my mind as i was going to post.Now i have another problem as the bundle i wanted, Radon asus 4.6 has been lowered to only 4.4GHZ.
have i missed something , is this a website error?
Hi do any of these support Extreme Memory Profile(X.M.P)????????????????
does any G.Skill do this?
If not what other brand is their that does support Extreme Memory Profile(X.M.P)?
