1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
GA-Z87-HD3 won't post
Discussion in 'Motherboards' started by Cal_G, 29 Jul 2015.
  1. Cal_G
    Gangster
    Hi all. Had this machine for nearly 2 years. Lately it has started to power on with no video output from either the on board or a GTX970.
    The odd time when it does post, you hear a beep and then it boots up as normal. This however, is now about once every hundred boots.
    Have unplugged all non essential peripherals, clearer the CMOS, replaced the battery. At a total loss with it now though.
    Cheers for any help
  2. wazza300
    Caporegime
    You did a long CMOS clear? Battery left out for 30 minutes?
    Also are you on the latest MB BIOS?
  3. Cal_G
    Gangster
    Never left it out for that long so will give that a go now, cheers. BIOS isn't the latest but if ever get it to boot again I will update it.
  4. wazza300
    Caporegime
    Try without the GPU installed after long CMOS clear,if it boots I would flash to latest BIOS using qflash,then try with the GPU installed
  5. Cal_G
    Gangster
    Sadly it made no difference after having it out for over an hour
  6. wazza300
    Caporegime
    idk what else you could try,do you have a spare psu to test with?
    try with no hdd's/gpu connected and only one ram stick installed
