Gaming Monitor Upgrade
6 Dec 2025
uk
Hi All, I'm trying to decide on a new gaming monitor for my sons pc. I'm after a 32 inch monitor so I can use it for work (i like to work in splitscreen mode) and have been looking at the ASUS ROG and MSI MPG ranges.
At the moment we have an nvidia 3060 gpu but may look to upgrade that later so looking for a monitor that will work with that but also perform well with an upgrade in the future.
The biggest decision point seems to be whether to get OLED or a more basic display - the ASUS seemed more attractive as we could put it in the 1080 mode if the gpu was struggling and until we upgrade that....
Budget is 500-600
would appreciate any advice or recommendation of good 32 inch gaming monitors!
Hi and welcome.
Oleds are stunning but can suffer burn in if using for a long time and there's text clarity also.
Maybe an IPS panel would suit better but what resolution do you want 1440p or 4k and dropping resolution when gaming ?
