I wasn't planning on reviewing these headphones but because the Sendy Egret won't be here until likely end of March I figured why not, closed backs have not been on my head for a long time and these are £180 so not exactly cheap cheap, but still pricey enough to have some good expectations, using real wood covers and a nice quality cable and looks sleek so..... What could go wrong??
Turns out a lot lol. Loads of microphonics because of the earcup and jack design amplifying the cable clatter, the midrange where vocals are sound lifeless and "floaty" with no sense sense of placement, just hanging there in the middle of my head, and whilst the bass is surprisingly good for a dynamic driver, the upper end of the treble gets lost in the wonky midrange sounds and lacks any sort of excitement.
I watched a bunch of reviews afterwards and to my surprise even channels that I thought would otherwise point out similar findings did not :/
The other negative is that you cannot use them with a balanced connection, seems the jack terminals inside are not set for balanced connections for some reason only 1 pole design, so you're stuck with single ended.
For this price I don't think they meet the original expectation I had, should be RRP at below half that price. They look great and the pads are very comfy (soft PU leather with microfibre contact patch and memory foam).
The storage pouch they come with is also cheap and nasty, feels like those bags you get with rice grains.
I feel this is an example of a headphone that has had much of its R&D budget put into style rather than sound quality.
I'd give it a 4 out of 10.
