I've just purchased
- Gigabyte GA-P35-DQ6 (rev 1.0) motherboard
- Intel E6600 Quad CPU
- Ninja Plus Rev b Cooler
As an upgrade for my games rig.
the other components retained from my exisiting rig
Corsair 2GB DDR2 XMS2 Dominator PC2-6400C4
Enermax 850W PSU
BFG GTX8800 Video card.
SB X-FI
So here goes.
I ripped out the old motherboard and assembled the new mobo, cpu and cooler, installed the video card, sound card etc.
All went well, posted up first time. So I went into the BIOS and just monitored temps for 10 mins and they were around 40.. So ok.. I now upgraded the bios to F6 using QFlash and that went fine, apart from at the end, it said press Enter to restart and upon pressing enter the PC switched off.
Switching back on.. Dead screen. CPU fan twitching, Case Fans blowing ok.
I thought i'd barfed the board. After stripping it back to bare minimum of CPU, Video and 1 Mem stick.. Still no joy, So I tried to clear CMOS, still no joy, so I removed the battery (after seeing a simlar problem on a DS4 mobo in another thread). Left the battery out for 30 mins.
After putting the battery back in, all was OK.. It posted again, (relief). So I went into the BIOS and confgured RAID, and I set the FAN warnings ON, I also told it to INIT the PEG (not PCI slot) first. (no overclocking settings at all). After pressing save and exit. Same problem.. PC powered down and upon restart FAN started twitching.
What I've found now is. If i remove the Video card, the CPU fan starts up to full speed. If I put the video card back in. CPU fan just sits there twitching.
I tested the 8800 video card in another PC.. it's fine.
I'm sure its a BIOS issue, so I've taken out the battery again for 30 mins, but now it won't post when I put the battery back in (like the first time above). I'm going to leave it for a few hours and re-try, but if anyone has any suggestions, it would help me greatly.
Other things i've seen are.
- When you get into the BIOS, set the memory voltage to the desired value. I do know that my Corsair memory wants 2.1 at least. (I intend trying this, if I can get back into the BIOS)
- I haven't got the additional 12V molex connector to the motherboard connected, as it states in the manual, for dual graphics cards. But as I have a 8800GTX, i'm going to try this next.
Thanks in advance
Enermax 850W PSU
SB X-FI
So here goes.
Thanks in advance
