Gigabyte GA_P35C_DS3R - Vistax64 Installation Help
Man of Honour
16 Mar 2005
Clevedon , Bristol
Help Needed :D !
I've got a Gigabyte GA-P35C-DS3R and will be building a new system with it shortly , installing Vista Home Premium x64.
The supplied mobo disc doesn't have Vista x 64 drivers on it , so i "think" i've downloaded what i need to get it running from Gigabyte :
motherboard_driver_sataraid_intel
motherboard_driver_lan_realtek_8111_vista
motherboard_driver_chipset_intel
motherboard_driver_audio_realtek_azalia
motherboard_driver_sataraid_intel_bootdisk_64 - (Preinstall driver, press F6 during Windows* setup to read from floppy)
Problem is the last one , i don't have a floppy drive.
I assume it is needed as i will be using a SATA hard drive.
Can i just copy it to a pen drive , and use that at the F6 prompt thing ?
Is anyone using a similar set-up with Vistax64 , that could help me out?
Thanks,
Mark
Yip just use the pre-installed Intel drivers and then install the latest drivers once Windows is installed.
