Permabanned
- 19 Jun 2007
- InURmama
QUOTED :
" Although we can say that we've already glazed upon a few P45-powered motherboards built by Gigabyte, it seems we ain't seen nothing yet. Although the upcoming P45 chipset from Intel is a mid-range part, Gigabyte has went all the way to make it enthusiast-worthy with the EP45 Extreme board which can be viewed below.
Starting off shy with features like support for 45nm 1333 MHz FSB processors and DDR2-1200 memory and CrossFire through one PCI-Express 2.0 x16 and two x4 slots, Gigabyte motherboard goes over the top when it comes to cooling. We like shiny copper as much as the next person but with the EP45 Extreme Gigabyte probably went over the top as, in addition to the PWM, northbridge and southbridge heatsinks and the heatpipes between them it has added a fin array just above the PCI slots. The whole contraption can be taken off though, and that will enable the connection of a water-cooling system to the northbridge heatsink.
Expected to be available in limited numbers, the EP45 Extreme is set to come bundled with a LN2 duct for the CPU and a new version of the EasyTune application. No word on the release date of this miniature copper mine but June seems like a safe bet. "
http://www.tcmagazine.info/comments.php?shownews=19381&catid=2
That funny looking Graphics Card has no Monitor outputs on it
How can you NEED that much cooling for a northbridge???
vid card even perform? As mavity surely would take all the heatpipe liquid onto the VRMs when mounted in standard ATX case?
