Yeah maybe on a 470, I've had the 480 up to 2100, still only 1 FPS in it over stock.
Ive set mine at 751 on the core, 1502 on the shader, havent touched the memory yet, (stock 1674mhz), stock voltage. Is it not possible to unlink the core and shader speeds on the 400 series? Havent clocked a card since my old gtx 280 almost a year ago.![]()
Weird that GTX470 is almost the same as my extreme tessellation/32x TRAA score... granted I have a higher core and memory clock but it shouldn't make that much difference.
EDIT: Wonder if the 260 drivers are bad for heaven performance mine was on 258.96.
Ahh, i see. Least its not another 3dm06, that bench really loved highly clocked quads.I have benched with my 920 at stock, it make little or no difference to the results, purely a GPU dependent bench.
Thanks for posting this up Rroff, gives me a ballpark figure. Bit higher than my own run with the same settings, 1920x1200 does drop mine a fair bit though.EDIT2: Get 44fps average at 800/1600/2000 with 4x AA, 4x AF, normal tessellation, 1680x.
Hi sunshinewelly, seems strange you can't get past 700, what power supply are you using?
