Garyfl, first off you need to join the right type of servers as a new player, and really you should do a quick Solo game to get familiarised with the controls and general game mechanics.
You need to use the right mouse button for iron sights (they are the crosshair)
If you join Hard, Suicidal or Hell on Earth servers when you are lvl0-4 chances are people won't be too pleased. Most servers have ff off btw, but still people won't be happy if you go on those servers until you're ready for it
Play a couple games on Beginner setting. This might be kinda boring but the jump from beginner to Normal is quite large. Normal is kinda like how Hard used to be
The in game server browser is pretty bad. You might find the right difficulty servers there with the filter, but it keeps resetting. Use the steam browser and join games from there (open up KF first tho). I like "Multiplay" servers as its FF off, just join one with Beginner or Normal on its name
You need to learn the difference between each zombie. Weld nearby doors and defend an area with the team. Press 5 and heal others or yourself with middle mouse button. Look after your team and hopefully they look after you
. Don't go running around the map until theres only a few left, then start heading to the trader
You still might not like it though as its a game designed around difficulty. You don't just win by simply taking part
. Don't go running around the map until theres only a few left, then start heading to the traderYou still might not like it though as its a game designed around difficulty. You don't just win by simply taking part
