Good CPU upgrade for Q6600 system
Permabanned
19 May 2009
Kirkby
I currently have a computer with an Asus Forumla Maximum motherboard and an Intel Q6600 CPU.
I would like to upgrade the system to the best I can without replacing the motherboard. I don't mind too much whether it's a dual core or quad core as I don't do a huge amount of video editing.
What would you recommend?
19 Oct 2002
Torbay, Devon, UK
Stick with what you have got the Q6600s should clock to about 3.6 (I think). Should last you a while yet.
But if you have cash burning a hole in your pocket. A Q9550 clocked to about 4Ghz.
Or just upgrade your Graphics (depending what you have now).
Permabanned
OP
19 May 2009
Kirkby
For some reason I can't get it to overclock on my board. I did originally get it clocked to 3.2GHz but for some reason it won't clock at all now.
11 Aug 2007
Manchester
Try updating your bios and making sure the settings in bios for the OC are correct. Sometimes mobo's have a bad habit for reverting to factory settings for that type of thing. Disable speedstep ect...
Permabanned
OP
19 May 2009
Kirkby
Thanks, I'll give it a go when I get home. It just seems odd that I used to be able to overclock and now I can't...ah well, that's computers I guess :)
22 Dec 2008
England
Learn why it's not overclocking and then overclock it. The issue will lie with bios settings, and probably previously running an unstable clock which reset to defaults after a crash.
There isn't a good cpu upgrade for a q6600. The q9*50 series are a little bit better, and the e8*00 ones might be if you never do anything multithreaded (in which case, why do you have a q6600?).
However to make a significant improvement you need to move to P55/X58, which means new board and ram too. And even then, argument can be made that it wont be much quicker. You have a very good processor already.
Permabanned
OP
19 May 2009
Kirkby
Yeah that'd make sense, however, the clock was stable but it did reset itself after about a month or two.
Permabanned
OP
19 May 2009
Kirkby
I currently have an ATI Radeon HD 3650 which I know is a pretty basic card, but I do very little gaming or anything that really uses the graphics card, so not sure it'd be worth upgrading.
