Graphics card help, 1060 vs 570 vs 580
11 Sep 2010
Brighton
I seem to be looking at the same options. The Sapphire linked above is £225. The Gigabyte and PowerColor below, are £200.
https://www.overclockers.co.uk/giga...ddr5-pci-express-graphics-card-gx-192-gi.html
https://www.overclockers.co.uk/powe...ddr5-pci-express-graphics-card-gx-18l-pc.html
Are these better buys (perhaps new prices since the Sapphire recommendation), or are they inferior cards?
Oh, and the Sapphire Nitro for £219 (which I've read is a good card):
https://www.overclockers.co.uk/sapp...ddr5-pci-express-graphics-card-gx-37m-sp.html
Thanks
11 Sep 2010
Brighton
Thanks Th0nt.
After some searching I've ordered the Sapphire Nitro+, as it seems to get nothing but good reviews.
I now need to sell the games - any idea which 2 are easiest to sell, and where?
Resident Evil 2, The Division 2 & Devil MayCry 5
OP
29 Dec 2012
Thanks Th0nt.
I#m not sure but I would suggest Gigabyte due to the warrant and support.
21 Jul 2005
Officially least sunny location -Ronskistats
:? eh he's already ordered it.
Regarding the games - one gets tied to your account (The Division 2), the other two are steam keys so probably straight forward to sell them on. Or you can setup the AMD account and hand that over as you can change details after.
11 Sep 2010
Brighton
Thanks. What did you get?
Thanks.
22 Dec 2011
UK
Hi guys im looking for a some help on a new graphics card but im not sure which to get.
Ive not played real PC games in about 2 years and im looking to move back and play some half decent RPG like I hear Monster hunter is a good one. so i dont know what I need.
Ive been look for a a 6gb 1060,
but what would be the benefit of getting a 6gb 1060 over a 3gb also what is the difference between a dual fan and a single fan model if both come with the same 3 year warranty.
then we have the AMD models which ive not really looked into
If I can I want to go with the cheapest option that will allow me to everything within reason.
Just get an rx 480 8gb used off the ebay or mm., should be able to get one for around £100 and the difference between the rx 580 and rx 480 is no more than 5%.
Deleted member 209350
D
What about a second hand 1070? Performs better than all the mentioned
