Just forget about inwards/outwards for a second. All bodies with mass "attract" each other (gravity). There is no "outwards", just "inwards"; bodies with mass do not repel each other like magnets with the same polarity. So, at the centre of a circle (yep, forget about the sphere for a moment) the question is "for the body at the centre of circle, how much gravity is exerted upon it by each point on the circle?" It doesn't matter what the actual number is... the point is that each point on the circle "exerts" the same gravitational pull as every other point on the circle (although with different vectors). The nett effect is that 0 force is exerted on the thing in the middle of the circle (all the numbers cancel each other out).
But you would be pulled apart if you weren't strong enough and the force was high enough (if you were a single point at the exact centre then the above is true?)
Also if you moved off centre you would be pulled to the side of the hollow? (again assuming force were massive
