Grease or pads for mosfet?
13 May 2003
Hamilton
Alright, I'm waiting on a mosfet waterblock arriving, so in the mean time I lapped down the other one - turned out the bottom of it was concave, now it's flat. Never lapped aluminium before, the appearance didn't change past 600 grit.
So, I have some thermal pads (decent ones) I also have some MX-1 arriving, and I have Ceramique.
Which would be best to cool mofsets on a motherboard?
Edit : I already realise the difference between Ceramique and MX-1 will be small, and also since I'm sure Ceramique won't conduct electricity, it's really a choice between pads and Ceramique paste.
Well, staying in place shouldn't be an issue, I'm using nuts and bolts to fit the blocks, so I'll be able to get as much pressure as plastic bolts allow.
I can't really think of any reason not to use the paste to be honest. I suppose I'm just asking in case someone says "Oh noes! Not paste on mosfets!"
Nah, no problem with using paste, I usually put a drop of ceramique on instead of the rubbery strips they seem to be using these days.
Is that block going to be a separate loop to the CPU etc?
Jokester
Now I just need to work out how to get tubing from one to the other :P
It's not going in a separate loop.The PC is "finished" and I'm left with annoying little fans that Abit put on. I realise this will impact the rest of the cooling, but to be frank the watercooling is instantly removing heat from the CPU/GFX card etc, so there's a bit of room in it.
Aside from that I can't fathom out how a second loop would be controllable or worthwhile - but it isn't _totally_ out of the question.
At the moment the water goes from the pump to the CPU, it goes through a mesh on the CPU cooler, everything else is a straight pass through (unless there's a mesh inside the GFX block, which I am not aware of). It's 1/8 tubing, so there's no problem with flow rate.
