** GREAT PRE-ORDER ONLY DEAL: OcUK NVIDIA GTX 970 REFERENCE CARD!! **
I have just checked the information on my card using gpuz and nvidia inspector and the memory onboard is sk hynix not samsung. I cant check the coils without taking the card apart but im wondering whether the zotac cards are just standard models but using reference coolers instead of their own.
I just got back from working offshore. Was very happy to find all the parts I'd ordered for my new gaming rig (majority from OcUK of course! ;) ) were all waiting for me, including three of these 970s. Like others I was surprised to see Zotac on the box, but not disappointed. Checked them all to make sure they were the correct reference design, and I'll probably give them a modest OC if possible. The only thing I'm wondering is, the Manli ones were said to be on 980 PCBs, so they could take 980 water blocks etc if I wanted to do that later. Is anyone at OcUK (Gibbo maybe?) able to confirm these are the same?
I would think the waterblocks would fit as the coolers on the 980 are identical so the mountings would be the same as well. The cards are the same length as well so thats a good sign.
From product description.
- Samsung memory guaranteed
Hmm, is that memory type ok? Durable? Any good for overclocking?
Also the Zotac manual is a little out of date. I had to double check that the card actually had Displayport connectors for my G-Sync monitor (it has several) and I'm loving the system requirements. 800MHz procesor and 128MB system memory.
But anyway, I was looking through there to see how I'd connect the power conectors to three of them in SLI. My superflower came with a couple of SLI-ready cables (and annoyingly only a european wall plug!) to link 2 cards, but also with enough other PCIe power cables to just connect each card individually so I'll just go that route unless anyone suggests not to?
I overclocked mine last night. 1500 stable core and the memory would go up to 4300 stable but because i use an inwin 904 case the cards temps were a little to high for my liking. So i backed off to 1450 and 4000 and increased the fan curve. The card now hits a max temp of 70 degrees. All this was performed with afterburner.
I shall update the description as Samsung is no longer available now but they are SK Hynix so OC range should be similar of 3800-4400MHz (7600-8800MHz). :)
Zotac, Manli, PNY, Inno3D are all same factory, this batch were built by Zotac as are a true recognised European partner so just makes warranty claims in 3rd year easier for us and the packaging is improved also. :)
Im happy with mine so its all good. The overclocks i acheived are plenty good enough and the temps are well within the safe range. I also havent noticed any whine when running unigine heaven 4.0 and my power supply is getting on a bit now. The only thing i will say is i wouldnt recommend running the fan at full speed as it makes more noise than i am comfortable with anything up to 80% is acceptable.
But that is why the NVIDIA cooler is best, it gives you that flexibility and the stock profile is designed for silence so fan is designed to keep the GPU at 80c or below under load on stock profile which is pretty much silent, identical to NVIDIA spec. :)
Yeah it is a great cooler and the card is very quiet on the stock profile. If my case had better airflow i wouldnt have changed it. I went with looks over functionality when i got my case.
Just wish the 970 came with 4gb of useable memory don't know why as I would probably never use the 3.5gb of memory but I think its still a bit of a deceptive too advertise it as a 4gb card. However the cooler looks fanttastic
'Extended warranty' Does that mean the 3yr or 5yr that Zotac offer on other cards?
3yr on these, Zotac won't give 5yr on a none official SKU as they don't offer it to other customers as it is my design and request, they just throw it in their generic packaging, but the warranty is 3yr which is great. :)
We advertise what NVIDIA advertise, that is how things will always be. :)
Ok cool! Just kinda misleading by them using "extended warranty" on the box imo, unless they mean 2 years + 1 extended year on top (3 years).
Quick question (followed by a slightly longer, slightly offtopic one), as I don't wanna blow these babies up, and my last daliance with SLI was dual 8800 GTs. I bought the 1200W Superflower Leadex Platinum to power my new rig which came with 3 split 6+2 pin PCIe power connectors labelled as "SLI-ready" (so one connection from PSU into 2xPCIe connectors), and 2 x 6+2 non-split connectors. If it had been three of each, great I would have plugged one of each cable into each card, but in this case I am hoping the "SLI-ready" cables mean they can be used either between 2 different cards, or in my case I am hoping to be able to use a single "SLI-ready" split cable to power each card individually. Is that the case? Be hard to see the point in them otherwise.
The split "SLI-ready" cable I'm talking about is the top one in this image:
And third from left in this image:
The reason I am concerned (and this leads a little off-topic, but I'm still mainly concerned about not wrecking my 970s!) is that my PC was freshly birthed yesterday. I'm pretty confident all the parts are compatible, but when I was testing the system to make sure it powered on (a previous build had a short somewhere that I had to remove/replace the motherboard into the case to solve) the PC would switch on fine for a couple of seconds, then switch off, and then almost straight away power itself back on again and remain on as if everything was ok. Unfortunately I can't remember at which point this started, because this only happens when I first plug in and flick the switch to on on the PSU. When the PC has previously powered up on the same "charge" (for want of a better word, basically if I haven't unplugged the PSU) then this does not happen, so the first time it happened and then did not happen when I restarted, I must have dismissed it for some reason. I have a feeling it was after the 2nd or 3rd 970 was connected, so I'll have a check of that this morning, but in the meantime if anyone knows a potential cause of this it would be great to find out.
Oh, and nothing is overclocked. No OS is installed yet, and I haven't touched the BIOS yet (something to investigate to make sure all the clocks are correct though). Its a fresh build of all non-OC'd parts. I will also double check the OC-genie button isn't pressed, although I'm pretty sure it isn't. But it does seem like a problem when its detecting the wrong OC settings and downclocking then restarting, but it all happens before the monitor comes to life to show me. I'm starting to think its a RAM speed issue though.
I'll also remove the CPU cooler and check the thermal paste coverage, but I don't see why the PC would stay on the second time if that were the issue.
Build:
MSI X99S SLI Plus
Intel i7-5820K with H110i GT AIO water cooler
4 x 4GB Corsair Dominator Platinum 2666MHz DDR4
3 x GTX 970 (from this thread)
Superflower Leadex Platinum 1200W
Samsung EVO 850 500GB SSD
