Hey guys, little update.
Running 10.12 cats and it was running like turd as usual. I reset all settings to default, then simply put the settings I had changed back, and it's running much much smoother! I couldn't believe it when I first booted it up, makes the game much more playable and enjoyable. However, after a couple of hours playing, the performance didn't seem so great again. I'm going to try the game again when I have time and see if that's still the case.
So, as suggested above, my advice is set everything to default in CCC and try then, even if you think all visible settings are on defaults.
