I’ve got a new gigabyte single fan Gtx 1060 3gb and I’m wondering if its idle/web browsing temp of 56 degrees is ok? I’ve read elsewhere that temps nearer 30 degrees would be more usual?
It’s inside a fractal design define mini (an old version) with both front and back fans running. The front is pulling and the rear pushing. I’ve got a Corsair 450 psu with its fans both pointing outside the case so it shouldn’t be interfering. The cpu is and old classic i5 2500 with the stock intel cooler. Could the cpu cooler be interfering perhaps?
Just thought I’d see people’s opinions here in case the new gpu temp is wildly out of whack.
Any advice greatly appreciated.
