- 11 Dec 2005
- Cheshire
EK GTX 590 Nickel Acetal water blocks, instock now! Cool your beast properly!
EK GTX 590 Full Cover Waterblock - Nickel Acetal @ £119.99 inc VAT
A Full cover block for reference design GeForce 590 GTX graphic card.
High performance water block for GeForce 590 GTX reference graphic cards.
Base is made of nickel plated electrolytic copper. New cooling engine involves thin fins cut into copper, providing extreme cooling performance and excellent flow over both GPUs.
Top is made of quality black POM Acetal material. The sealing is preformed by quality rubber washers withstanding temperature range from 0 up to +80 degrees Celsius. Block is mounted with enclosed M3x8mm DIN7985 screws.
Fittings can be used on both side of the block (up and down) and 2 plugs are enclosed!
Enclosed:
- water block
- mounting mechanism
- thermal pads
Only £119.99 inc VAT.
ORDER NOW
Enclosed:
- water block
- thermal pads
ORDER NOW
