So i have on pre-order the Obsidian 500d RGB case and am intending possibly to build in the H150i pro AIO ( or the new ROG one if it ever appears )As the case comes with 3 RGB fans built in the front i was thinking of using these and also the radiators existing fans on the other side of the rad? - mainly because these will be spare as i have other ll120's for the top and rear.
Questions are:
As this is now a rad with a fan either side will there be any issues? noise etc?
Will the fans need to run at the same speed to cause less resistance or turbulence.
Not sure on this whole static pressure thing but these will be different fan types either side so any issues there?
Thanks, any advice welcomed.
Questions are:
