H80 replacement fans ?
Settled on the Noctua NF-F12 PWM 120mm as stats wise they are the best, 93.4 CFM and only at 22.4 db.
*EDIT* one thing i will say is the colour scheme will not be to everyones liking, idle temps are down by 1 degree 'c and load temps have not changed but they are sooo quiet, amazing fan, why OCUK dont stock this fan and only stock the old P12 i do not know :confused:
Just received my fans from OCUK, Thanks guys! And thanks for the Haribo ;)
Got 3 Akasa Vipers, 2 for the H80 fan and 1 for the side window over the gpu to cool my cpu heatsink mod, works wonderfully! The 2 sickleflows from the rad have gone top and front of my case.
Temps on prime95 running for 30 minutes went from Max. 52 degrees to Max. 25 Degrees... So either something was wrong with my sickleflows or they just arn't got rad fans!
