Thanks Duffman.
Are you seriious there is no way to mount a 120mm fan onto the duct ?
Wouldn't the fan mount onto the HD side of the duct like the way you mount fans on the ATCS 840 ?
Just had an email from Coolermaster, will send a new side panel out, once they have them in stock. Now thats customer service...
WOW you managed to put together shop bought parts
The only thing that would have required some work from yourself , you didn't do ! ( the wiring on the optical drives )
Not sure why you needed to create a post about a very 'generic' build
It frustates me that installing basic shop bought hardware deserves a thread.
Looka at w3bbo or rjkoneill, to name a couple, they put some effort into a build.
Think of something different if you want to create a thread, not the 'shopping list' type of build.
I receive messages daily, and respond to them, giving advice on modding/tips etc.
Sorry if i have offended you, but anyone can put together Lego.
He is only showing off his new build even if it is similar to most out there
This as all been said before, no need to go over old news...
I got a spare 200mm fan from the coolermaster shop
Link http://www.coolermaster.nl/shop/index.php?cPath=88
Also email there customer support on same page bottom left hand corner, tell them your problem, and i bet you will get a replacement fan, HAF X is still under warrenty.
Red
Just had a delivery at home, and a new side panel for my HAF X has arrived.
Have to say how good the customer service from Coolermaster is. Very Impressed.
Red
Ah so there is a dust filter on the bottom grills . Planning on buying this case later this week and that was the only thing putting me off.....especially having 2 long haired cats in the house.
i've emailed they customer services ([email protected]), how long did it to get a reply?i asked there customer services and they sent me one in the post. Now that's not bad...
