What is the largest Radiator I can fit in this case?
And how many fans can I fit around the radiator?
I am new to watercooling, so any help will be greatly recieved. Any suggestions for parts would be helpful. My aim is to have a Quite and cool pc so i will most likely have a low airflow radiator.
I was hoping to watercool my cpu, gpu and use the built in water block on the motherboard to cool the NB.
I would hope to spend £300 max. £200 if possible
My specs:
Antec Truepower Quattro 1200W
PowerColor HD 5870 PCS+ 1GB GDDR5
Gigabyte GA-890FXA-UD7
AMD Phenom II X6 Black Edition 1090T 3.2GHz
Coolermaster HAF X
BL2KIT25664BN1608 4GB kit (2GBx2), Ballistix 240-pin DIMM
My specs:
Coolermaster HAF X
