- 18 Dec 2007
Well, Today I turned on my computer to receive the warning 'Windows detected a hard disk problem'. I downloaded 'SeaTools' and have scanned through various options, with the hard drive failing all the tests. I assume that there is nothing really that can be done? and the best thing to do would be to backup all my data and get myself a new drive....
unless... anybody knows some tools I should download to try and find out what the problem is? / If its possible to be fixed once I know what the problem is.
If the only solution is a replacement, I would rather find out if i'm still under warranty. Checking the Samsung website however, there isn't an option to check for my hard drive. what does this mean in terms of getting a replacement?
The drive is;
Samsung SpinPoint F1 500GB SATA-II 16MB Cache - OEM (HD502IJ)
bought from OCUK on the 26 May, 2008.
I've never had hard drive failure before so don't really know the 'standard procedure' of checks / possible fixes (although I'm assuming this error means its only a matter of time before the drives breaks)
Any advice/help would be grateful
Thanks
The drive is;
Thanks
