Hard drive noise from speakers, hardware problem??
16 Mar 2005
Whenever there is any harddrive activity or when I scroll up or down on the internet I get quite a loud whirring noise through the speakers. I have changed the speakers to try and fix the problem but the same still occurs. I had a problem similar to this before where the psu was causing the problem however I have changed the psu and the problem still occurs. I am using an Asrock dual sata 2 motherboard with onboard sound. Also whenever I try to run battlefield 2142 the pc is restarting, I have removed the side cover and put a fan over it and it still keeps restarting. If you need any other information I will provide it. Cheers
Jon
10 Dec 2006
Could you post your full system specs (inc. PSU).
Have you tried updating the audio, and chipset drivers for your motherboard?
18 Oct 2004
Kent
I also get this! However, I can only hear it through headphones or with the speakers up very loud. I was beginning to think I was going mad...thought my scrollbars needed a drop of oil or something :D
OP
16 Mar 2005
CPU: Amd Athlon 64 3700+ Socket 939
Memory: 2 x 512mb DDR pc3200 Unmatched single channel
Graphics:9800pro Ati 128mb
Motherboard: AsRock 939Dual-Sata2
PSU:Antec 550w Truecontrol
18 Oct 2004
Kent
I was getting the problem using a Creative Audigy 2. However, I went to check my mixer settings after seeing malachi's suggestion, and the background noises ceased entirely when I muted CD audio....I can only assume it was some sort of static interference being transferred from the CD drive down to the sound card.
10 Dec 2006
jonboyo said:
Are there any particular sound cards that you would recommend. Or would any dedicated soundcard help?
A few years ago I bought a Sound Blaster 128 PCI (very old) for less than a tenner just to provide me with some audio interface :) Works fine if you just need it for general usage!
3 Feb 2007
Minstadave said:
Its usually electromagnetic interference affecting the onboard sound, if it really is a problem investing in a dedicated sound card will sort it.
I would second that it’s an earth type problem all you can try, make sure the motherboard I/O panel is in contact with the sound block. Most I/O panels come with legs which basically look like a bit of metal bent down slight (they are springy) this then comes in contact around each port on the back, which in turns earths to the case.
Permabanned
27 Aug 2006
bideford/exeter, devon
I get this using a soundblaster audigy4 se, but I didnt fit the backplate to my motherboard - shouldnt be relevent though as I assume that only applys if your using onboard sound.
