Hello,
This is the hardware used for my current home server:
G1840
MSI B85M-E45
12GB RAM (2x4GB and 2x2GB)
1 x 64GB Crucial M4 SSD
2 x 2TB Samsung F4 Harddrives
1 x 6TB WD Red Harddrive
TBS TBS6905) Quad DVB-T2 TV Tuner
Superflower Goldden Green 350w PSU
Tower with 1 x 140mm exhaust fan and 1 x 120mm intake fan (both fans thermo-regulated).
Until recently, I was running Windows 10 on it but have made the leap to Linux and am now running it headless with Openmediavault.
In addition to just serving my client's with media, I also run TVHeadend on it for recording all my TV.
Two main things are a problem:
1. I cannot get WOL to work.
2. I cannot find a satisfactory way to get the server to sleep when idling and then wake up for scheduled recordings (this was really easy to set up with Windows but really complex with Linux).
Is it just easier just to leave my server on all the time instead or do you think I should keep on trying to fix the problems instead?
If it is suggested that I leave the server on, what sort of annual cost do you think it would be, in comparison to letting it sleep? As a general rule, the server would probably be sleeping from about 8am to 6pm during the week.
Would it be worth thinking about upgrading my hardware with something a bit more economical/quieter?
G1840
MSI B85M-E45
