has anyone got pics of their cm 832 system built
13 Dec 2007
im in the middle of building mine but i feel ive got things the wrongway round
help
thanks
Pre
hi,
just want a view on the insides please and im a bit stuck on the wiring of the front panel to the mother board
cheers
Err, i didnt actually use mine to keep the amount of cables down :S (well the USB, Firewire and front audio)
Dont know if the pics in this post are of any use ?
Whats the problem ?
Let me know if you need any help :)
cheers pal
i wasnt sure wether to go for a btx type or atx for this type of case
which way would be better ?
right now im building around in atx type formation.
if you already havent guessed this is my first time im buildig a pc
oh ive a ground wire from the psu where do i need to put this???
i think this needs to go the the case somewhere ......if so where?
thanks
Pre
I have an Asus P5B Deluxe (ATX) and its fine - nice and roomy
As for a "ground" wire - are you sure its not a monitoring lead for the PSU fan speed ?
If so there is a connector on the board - but youll need to check your mobo manual
ive just read the manual and it states that its a anti noise wire but it does not state where to place it !
theres nothing on the mobo manual
thanks
