1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Haswell build opinions ~£750
Discussion in 'General Hardware' started by mitch212k, 14 Jun 2013.
  1. mitch212k
    Hitman
    Hi all,
    I'm looking to order a load of kit over the next few days for a Haswell setup, coming from my current E8400/5850 machine. It is for mainly gaming, general use and some CAD/engineering software bits and pieces. I will be reusing my Thermaltake Kandalf full tower case, Coolermaster Silent Pro M-600W psu, storage drives and I've purchased a 7970 from the MM. I require everything else and I don't want to spend any more than the current £540 for the below setup. I'd also like a decent sized SSD in the build. Does this look ok to everyone?
    [​IMG]
    Thanks!
  2. stulid
    Capo Crimine
    You don't need the thermal paste, the Be Quiet cooler comes with a little syringe of it.
  3. danclivo
    Hitman
    Spec looks good. I'm assuming you already have an OS since you didn't mention it?
  4. Doomedspeed
    Capodecina
  5. mitch212k
    Hitman
    @stulid: Thanks, didn't realise!
    @dan: I do indeed have an OS
    @Doom: I chose the SSD based on the max read/write speed compared to cost. Hence the SanDisk came out on top. Is the plextor worth the relatively small saving compared to the loss in max write speed?
