Eh? My ASHP can supply more than 55C (I think my Target flow temperature is set to 60C).
Also why would my heating system need 80C?
They can, but not very efficiently. 60C is more likely the limit. But if you could drop that to, say, 35C flow, your COP would jump up enormously. Not that 35C is practical, but weather compensation at least allows you to have a variable flow temperature and therefore a variable COP (SCOP).
Old heating systems were often designed for 80/60C because there wasn't enough heat transfer, so flow temperature was high. It's just that techonology has massively improved so flow tempreatures have reduced. Also, if you have 80C stored water then you don't need to worry about legionnaires. But, a lot of modern systems don't have stored hot water and generate it on demand (like a combie boiler) so you don't need to pasteurise your stored hot water.
Well yes and no, all devices that heat on demand right now apart from heat pumps/ac type units are all in effect 1:1 devices, immersions, instant boil taps, showers etc etc
An immersion is 100% efficient as is a kettle, an electric shower etc
My immersion is like 3kwh (its a backup) it could be with the correct cable and switches 20kwh.
Same with a kettle they are 3kwh since thats the max they can pull from a socket, Ive seen instant hot water heaters that are 6kwh, and as I said a shower is in effect no different its just a heating element.
You don't need to have poor controls thats just whats installed typically. You could have very sophisticated controls if you wanted them, the heating element just has an on off switch (make contact to allow energy to flow), what chooses when to do that and to what extent etc is completely irrelevant to the fact that anything that heats water directly at 1:1 is going to be expensive to run!
Your immersion heater may be 100% efficiency in heat generation, but not in heat transfer. No way will you get your 3 kWh of heat out of it unless you've spent time fixing it.
Where else is a heater losing ‘efficiency’ anyway lol. It’s not like an immersion heater is giving off light
If the flow rate is too high then there may not be enough heat transfer. So you may be heating your water up to 70C to heat the water in your cylinder, but if the water moves too quickly through the coil, it may leave the vessel at 68C for example. That's deeply inefficient. Or, the temperature in the cylinder is equal to the temperature in the coil (i.e. you've reached your set point temperature) bt the heater still pushes water through unecessarily.
