29 Oct 2011 at 15:13 #1 Hanuki Hanuki Associate Joined 5 Apr 2011 Posts 279 Location London, UK I wanna use Heat Shrink Tubing for my fans in my case? Is it recommended not to i wanna hide those horrible yellow/red/white wiring...?
29 Oct 2011 at 15:15 #2 PhillyDee PhillyDee Soldato Joined 12 Feb 2007 Posts 14,117 Location South Shields You would use braid on the cables, and heatshrink tubing to sealthe ends of the braid. You can pick up 3mm braid quite cheaply.
29 Oct 2011 at 15:32 #3 Hanuki Hanuki Associate OP Joined 5 Apr 2011 Posts 279 Location London, UK Case fan wiring is small example here
29 Oct 2011 at 15:39 #4 PhillyDee PhillyDee Soldato Joined 12 Feb 2007 Posts 14,117 Location South Shields Heatshrink is reasonably inflexible, and tends to kink. Here is a tutorial: http://forums.overclockers.co.uk/showthread.php?t=18280993 This will give the effect you want, and it looks far better.
29 Oct 2011 at 15:41 #5 Hanuki Hanuki Associate OP Joined 5 Apr 2011 Posts 279 Location London, UK 1 question where can i buy this does OCUK stock it?
29 Oct 2011 at 15:46 #6 Hanuki Hanuki Associate OP Joined 5 Apr 2011 Posts 279 Location London, UK Also, i dont feel comfortable removing the pins in the fan =)
29 Oct 2011 at 17:13 #7 moogle moogle Soldato Joined 4 Nov 2006 Posts 2,984 Location London Hanuki said: Also, i dont feel comfortable removing the pins in the fan =) Click to expand... I don't think cable sleeving is the thing for you then
29 Oct 2011 at 17:13 #8 PhillyDee PhillyDee Soldato Joined 12 Feb 2007 Posts 14,117 Location South Shields You can do a bodge job, and get the braid over the full connector, and cable tie into position.
18 Aug 2017 at 06:58 #9 Lijun Lijun Associate Joined 17 Aug 2017 Posts 1 You can try China Shenzhen Dicore Heat Shrink Tube http://www.dicoretubing.com
