I'm renting an out building to use as somewhere I can set my decks up and so on due to complaints from neighbours.
It's around 30 foot by 15 foot, 2 of the walls back onto a corridor, and the other 2 are outside walls.
It's freezing in there, i've currently been using one of those small electric heaters with the 3 bars and it's done the job as i've had it right next to the decks so I can feel it.
It's broke though and i'm wondering if there are any better ideas than going out and buying another one (they're only a tenner or so).
Not wanting to pay too much as the heater was OK (ish!) and i'm not sure how long i'l be renting it for.
I only really use one end of the place as theres only the decks and a PC in there. I was thinking about getting some heavy duty lining/curtains and hanging them down from the ceiling so that would keep the heat in "my section" a bit better. Any idea where I can get some from on the cheap? The ceiling is quite high....i'd say 25-30 foot.
Another idea is to build a room inside the room - this would help with soundproofing too but I don't want to pay out for the materials and so on.
Guess i'm looking for quick fixes really. Any ideas?
