Duel said:Holy ****, you have nearly 60,000 posts!
Do you hold the world record for a forum?!?!
Sorry to hear about your card btw.![]()
Vegeta said:Ye I told you it wasnt broken
Similar thing happened to me, I just left the computer off overnight and it worked the morning later, my monitor maybe a little better than yours so it fixed itself!
Concorde Rules said:RMA it, I did![]()
Bigstan said:How thoroughly embarrassing.
The card isn't kaputt after all.
I tried a different monitor and it worked fine so I put the old monitor back in, switched it off and switched it back on again (the monitor) and it was perfect.
It never occurred to me that it would have screwed with the monitor![]()
Thanks for all the hints though guys - they will come in handy when I have another go later![]()
Stan
lolMr Mister said:my offer of a tenner still stands![]()
88 degrees?Bigstan said:LOL.
I'm sure it does. I think I'll politely decline for the moment though![]()
I tried again with ATI Tool and it was useless, it wouldn't go above 650/750 without switching off so I abandoned it and used ATI overdrive instead which goes all the way to 690/800. Temp gets up to about 88 degrees with that anyway so I doubt I would get much more unless I got better cooling for it.
Stan![]()
For 24/7 usage i'd say 1.45 is about the most you'd want.Bigstan said:I upped the voltages a little bit but wasn't sure how high would be safe - how high would you say was a safe maximum?
Stan![]()
