Help Choosing: Corsair HX520 or HX620 PSU?
17 Jan 2005
England
My knowledge of power needs is non-existent , so I could use some help. Based on the following system specs, will the HX520 be enough, or would I be better of getting the HX620?
AMD Athlon X2 4600+
ASUS A8N-SLI Premium
2GB Crucial Ballistix RAM (4x 512MB @ 2.8v)
nVidia GeForce 8800GTX
Creative X-FI Extreme Gamer - PCI
Linksys Wi-Fi Card - PCI
Hauppauge WinTV-NOVA-T 500: Dual Digital TV tuner - PCI
2x SATA hard drives
2x IDE DVD writers
6x USB devices
3 or 4 case fans
Thanks for your help.
No way. The 520W is way more than enough. You only need the 620W if you're going SLI, and even then I reckon the 520 would cope fine.
Dingleberry88 said:
And isn't 2.8 a really high voltage for RAM?
Not for DDR ram. It's about average. :)
Yup i'd say save the extra as even if you upgrade your cpu for a c2d etc a 520 should handle it with ease.
