Desperately Seeking Assistance on my ASUS P5W DH with 4GB memory.
I’ve just built (or am in the process as some parts are still on order) my 1st Custom PC for 3 years. I am technical enough having worked in IT for 15 yrs to know the general pitfalls of making my own machine. This is the 1st machine I have built in regards to wanting to do some serious overclocking with it. Everything at the moment is running at Stock.
I have 4 GB ((2 x G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ)) trying to be installed into ASUS P5W DH Deluxe i975X, S775, PCI. It will boot up with 2GB fine and even 3 GB but as soon as the 4th stick is installed it fails to POST.
I can arrange the sticks in different slots in the board. Memtest runs fine and tells me the actual individual sticks are fine. With 2GB in (I have tried all 4 sticks in various quantities) I can run Prime95 and the Orthos Prime Beta for multiple hours without any problem. I have left the mem timings at SPD and have also tried them at 4-4-4-12 and 5-5-5-15 at both 2.0 and 2.1 v which is the proper volts listed on the box. I have also loosened the timings completely but no go at all.
Is there a compatibility issue between these sticks and the motherboard when running 4GB?? They are all running default there is no over clocking going on in the board? The memory a week old and whatever 2 sticks of ram I use the machine boots up fine it just won’t with all 4 sticks in it. The fans turn on but the machine does not post any bios information or video signal as if it won’t go past the point of power being provided and nothing else.
I also know XP can not use more than 3GB of ram but I am also testing the VISTA Beta's which will also be running 64Bit OS so will be able to address the full 4 GB of ram
Full Spec of the Machine or will be.
Conroe E6600 2.4 (Installed)
Tuniq Tower120 (Installed with AS5)
ASUS P5W DH (installed running 1305)
4G of DDR2 HZ PC2-6400 (2x1GB) (installed – Will only Post with 2 GB or 3 GB)
X1950 HIS (On-Preorder) Running a Matrox MGA PCI graphics card as a temp.
2 x WD150 Raptors in Raid 0 (Installed with Zalman HD coolers)
Samsung DVD drive (Installed)
Antec P180B (Installed – 3 x Sharkoon SilentX 120mm 1000 fans arriving Monday)
Seasonic M12-600 (arrives Monday using a loaned Seasonic S12 at the mo)
24 inch Samsung 244T (installed)
Any help would be appreciated I have a tech support call open with Gskill at the moment but am having trouble even getting to the PoS Asus website)
Regards
Khalsa
Regards
Khalsa
