1) save your cpu oc in one of the empty profiles
2) revert everything back to stock values
3) try ocing your ram
i first of all only oc'd to 1866mhz using ocuk's achieved oc
Overclocking Features (Not Guaranteed)
- 1600MHz (7-8-8-24 1N) @ 1.40v
- 1866MHz (9-9-9-27 1N) @ 1.40v
- 2000MHz (9-10-10-28 1N) @ 1.45v
- 2133MHz (10-10-10-28 1N) @ 1.45v
- 2400MHz (11-11-11-28 2N) @ 1.50v
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M
then i tried experimenting. i first of all upped the ram voltage to 1.65v and VTT to 1.98v. these are the highest safe volts for IB processors.
you really need to play with the secondary timings to get up to 2133mhz and by the looks of things IF your board allows you to play with thirds then you will be able to look for higher clocks.
once you have found your desired speeds and timings then you need to work on dropping the volts and timings and using memtest86 to test your ram.
i am just finishing a 12 hours test (with no errors), some say you should do it longer but iv been ok with 12 hours memtest and them 3 MAX runs on IBT.
due to my board i am only able to go to 2133mhz but i have upped the bclk to 103.1, this is only really safe on IB. with my bclk set to 103.1 i have achieved a clock speed of 2199mhz 9-10-10-21-1T my secondary timings are
4) once you got your ram oc'd save it to another profile.
5) once you have your ram oc'd then go about oc'ing your cpu again.
6) IF you get your cpu and ram oc'd save that profile. if all else fails at least you have your two saved profiles (cpu & ram)
i hope that helps
