rmuir said:se k750 for a number of reasons but mainly - far superior camera, ease of use, build quality, battery life. Used both these phones in the last year and se wins hands down. Only reason i had to use the nokia was cause some scumbag nicked the se.
Kappa said:Better battery
garyh said:... you'd be better off getting a W810i.
garyh said:Quite the opposite if you actually look at the specs on the manufacturer website.. I've had both.. and I can easily say the K750i has the better battery life and far superior build quality.. SE are way above Nokia these days on design - the only thing that lets them down on the K750i is the joystick... you'd be better off getting a W810i.
