Help me overclock my Gigabyte Radeon HD 7950
b4z
b4z
11 Mar 2005
London
Just finished building my new PC:
Intel Core i5-3570K 3.40GHz
Gigabyte Z77-D3H
Kingston HyperX Genesis Grey 8GB
I am now staring at the Catalyst Control Centre > Performance > AMD Overdrive
And my question is just how high can i slide the sliders? :D :D
And how can i test if its stable? :p :p
Current GPU Clock: 900 Mhz
Max Slider: 1100 Mhz
Current Memory Clock: 1250 Mhz
Max Slider: 1575 Mhz
Current Power Control : 0%
Max Slider: +20%
Thanks!
25 Nov 2011
The KOP
Your card can max them out But they is a big chance it wont be stable without increasing the voltage. Put them all way to right and download Heaven 3.0 and run a Bench with OCuk settings see if you pass a run. If it crashes you will need MSi Afterburner to unlock the voltage.
If it passes just go right ahead and play some games BF3 a good game to start for stable OC.
Gigabyte Z77-D3H
Max Slider: +20%
Thanks!
25 Nov 2011
The KOP
Heaven 3.0 settings
API = DirectX 11
Tessellation = Normal
Shaders = High
Anisotropy = 4x
Stereo 3D = disabled
Multi monitor = disabled
Anti-aliasing = 4x
Full screen = enabled (yes)
Resolution = 1680x1050 or 1920x1080
25 Nov 2011
The KOP
Am not sure about this. But wouldn't him updating to this Lock out him unLocking the Voltage control?
there is a new bios for the card on gigabytes site. http://uk.gigabyte.com/products/product-page.aspx?pid=4121#bios
ups the clocks to 1000 plus the voltage though. Probably better off just ocing manually but it is a option.
(check which bios u got. there is a tool in d/l that will check what bios u got. U will need to have the f2 bios to use the above 1)
30 Sep 2008
surrey
That Bios seems a bit pointless if it locks voltage . it is easy to get the gigabyte to 1000 on stock volts with the old bios . Mine is running at 1040/1475 with no volt increase, and i still have my voltage unlocked if i want it!
10 Sep 2012
No it doesn't lock the voltages, and i agree its a lot easier to manually oc it. With the above its set to 1.2 and u can get a way better oc with that voltage. Hell most can get that with stock voltage.
But its an official bios so just another option that I was pointing out. :)
