Ok guys, here's one to get your teeth stuck into. Apologies for the long post...
I've just about completed a migration from our old servers (DL380 G4s) with local storage and VMWare Foundation to new servers (3 x Sun X4440), a SAN (Sun 2510 iSCSI) and VMware Enterprise.
I now want to turn my attention to how to back it all up. Our disaster recovery is taken care of with DoubleTake Livewire, which replicates all our critical data offsite, so I'm coming at this from a file recovery/local problems/users deleting files point of view.
So here's what I want to achieve:
And here's what I have available:
Previously I've used the free version of ESXpress to backup the system drives (putting data volumes into independent mode to prevent them being backed up) to the NAS and a script to delete the last day's backups at the end of the day. Then, I've run weekly full backups of the data with BackupExec and daily incrementals to the NAS. Then a full archive to tape every month.
That worked well enough in theory, but there's a few problems. Firstly, there's no free version of ESXpress and with VI4 out soon, I want to move away from that. Plus BackupExec seems pretty poor at media rotation with B2D - if you set a maximum size for a B2D set and configure the job to append/overwrite if no appendable media available, the set fills up and goes offline instead of being overritten...
Ideally I'd like to use VCB as its part of our VI licensing, but I dont have enough space on the backup server to stage all of the VMs. If I used file level VCB, it doesnt capture system state.
So, what would you guys do to meet these requirements, preferably without spending too much (already spent 30k on the upgrade so far, cant imagine much extra would go down too well...)
Cheers!
- Quickest possible recovery of VMWare system disks
- File level backup of data volumes
- Recovery of individual messages from Exchange 07
- Recovery of individual DBs from SQL 2000
- Retention of file level data for 14 days
- Only need to retain system volumes for 1 day
- Archive of data every month
- Sun 2510 iSCSI array with HP 2510G switches
- Backup server - HP DL380 G4 with 6 x 36gb 10k disks
- Buffalo Terastation Pro 2TB NAS
- 2 x SDLT320 Tape Drives
- BackupExec 12.5 with Exchange and SQL agents
Cheers!
