Gelid Tranquillo - £25.99 at last check and it's very good performance on the Sandy Bridge chips. Not sure how they cope with Ivy Bridge as they run hotter.
Well, if you think you may go sli/xfire in the future, then this mobo will give you x8/x8,
http://www.overclockers.co.uk/showproduct.php?prodid=MB-390-GI&groupid=701&catid=5&subcat=2261
Is there really much difference between brands, cause a lot of them seem to have the same spec, or is it mainly down to preference?
EDIT:
PS also does it matter having AMD card and a Nvidia Mobo?
Is my Mobo compatible then? ive had a quick look but i cant see what im looking for, at the moment its all a mix of numbers and letters, but im learning slowly....i think
