Help! Msi 580gtx lightning extreme
18 Mar 2007
Just bought the above card and it needs 2 x 8 pin power connectors. I currently have the enermax galaxy 1000w power supply from a few years ago and it doesn't have any 8 pin sockets. Do I need a new power supply?
The msi manual is less than useless, but it does come with 2 adaptors that convert 1 x 6 pin into an 8 pin but does not comment on them in the manual.
Does anyone know if 2 x 6 pin power connectors from this power supply would be sufficient for this card?
Many thanks guys
Nic
I think you have your answer in the 6 > 8 pin converters?
Use those, they will work. Manuals surely dont need to comment on cables.
It's just the manual says as a minimum requirement, 2 x 8 pin power connectors. Hope my galaxy can supply enough current as well. Just wanted to make sure from you knowledgeable people on here!
Thanks
Nic
6 pin deliver up to 75 w, 8 pin 150 w. Combining 2 6 pins is ideal and they are designed to carry that load.
Using Molex to pci-e 6/8 can cause more issues depending on the design of the PSU.
The adapters just convert 1 x 6 pin to 1 x 8 pin - are you saying these won't be sufficient? Why would they include them if that was the case? Thanks
Nic
According to the review for the PSU here:
http://www.overclock3d.net/reviews/power_supply/enermax_galaxy_1000w_quadsli_atx_psu/2
your PSU will deliver a total of 492W (41A) for GPU and system drives. Cosidering two PCI-EX8 pins is (2x150W), plus the 75W on the PCI-E bus of the motherboard, the Msi 580gtx lightning extreme should consume no more than 375W of power. So 492W-375W still leave you around 117W left for the system drives.
So basically you will need two PCI-E 6pin to PCI-E 8pin cable/adapters.
Just to be clear, I need two 1 x 6 pin to 1 x 8 pin or do you mean I need two 2 x 6 pin to 1 x 8 pin adaptors?
You mentioned that the Msi 580gtx lightning extreme comes with 2 adaptors that convert 1 x 6 pin into an 8 pin, so what you have to do is just plug your two PCI-E 6pin into these two adaptors separately, so your two PCI-E 6pin becomes two PCI-E 8pin. Hope that clear things up for you.
Thanks that's great, although I have seen some people combine 4 x 6 pin into 2 x 8 pin which is why I ask. Some say 6 pin are limited to 75 watts others say that's not true and the extra pins are just grounding etc - not an expert just want to plug it in and unleash the power!
I won't claim that I'm 100% clear on the subject of how the 8pin works, but since MSI only provide a pair of 6pin to 8pin adapters that each only require a single 6pin, that means it will works.
Thanks - will give it a bash.
How would I know if the card wasn't getting enough power - either amps or wattage being too low - is there a program that would monitor this - would it just exhibit as a slowing down when playing games or would it crash?
Not that I would know if the game was slow - going from an 8800 !
Thanks
Nic
How have you got on with this Nic? I'm in a similar position, I have the same PSU and a 6970 coming (only need one 8pin connector).
I'm a little confused by this?
Wouldn't this mean the card will only be getting 150w? (2 x 75w connectors) When it really needs 300w (8pin x 2)
Cheers
You need to plug in the 8 pin connectors, the adaptors will work. They do that same thing as the 2 6 pin to 8 pin adaptors.
What I would advise is to use both modular 6 pin pci-e connections on your PSU one to each adaptor. Don't load a potential 25 A on one modular wire. :)
Yes the extra pins are just grounding, but they need to be plugged in, in most cases. :)
The 6 pin connector means the card shouldn't draw more than 75 W from it based on PCI Express 1.1 Specifications. If the card uses an 8 pin connector it shouldn't draw more than 150 W from that connection based on PCI Express 2.0 specification.
It's got nothing to do with what the PSU can actually do. :)
