Can anyone point me in the right direction for some 140mm PWM case fans ?
seems plenty out there now but in the past I've used the Thermalright TY-140 but they are not brilliant and occasionally make ticking noises etc.
Just need bog standard 125mm square mounting holes (i read the 150mm Thermalright is not standard mounting)
Need to be Smooth and quiet with good performance.
Cheers
Cheers
