Swear to God this will be my last thread here for a while, over the week I feel like i've started about 10.
Anyway just started playing S.T.A.L.K.E.R SoC with Oblivion Lost 2.2 and after about an hour my card started to produce a burning electrical smell. So far these are the things i've done:
1) Uninstall the drivers, restart then download the NVidia driver folder. Re-download fresh ones and install again.
2) Re-steated the card, made sure now wires or foreign objects were in the way.
3) Ran a different game, CS:S which seems to be working fine.
Now my power supply has only one 6 pin plug so i'm using a 2x4 pin to 6 pin adapter. However the adapter i've got seems to be missing one pin, if you look at the adapter if it's facing you, the top row middle pin is missing and there isn't a wire there.
Is that what's causing it i.e it's not getting enough power or do I need to ring the Wales depot again for a new card. My PSU is 800 watt so I don't think that's the issue.
Thanks.
Thanks.
