1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Help needed changing colours of ARGB LEDs on Kolink fans
Discussion in 'General Hardware' started by Beartov, 15 Sep 2021 at 01:38.
  1. Beartov
    Ahoy there
    I got a new PC recently and am trying to change the colour of the LEDs. Downloading Armoury Crate worked for the light on my motherboard but it doesn't detect the LEDs on the fans. For reference it's the Kolink Glass SE ARGB Micro-ATX Case.
    Is there a way to get Armoury Crate to detect the fans, or perhaps a different software that would work? I noticed Kolink sells controllers for programming LEDs and assume this may be the way to go but wanted to make sure first. Any help folk can provide would be much appreciated!
  2. Eeekster
    Gangster
    Hmm, might be the same issue/solution as I had with the Kolink Mesh M-ATX RGB - there is a button on the front IO panel that cycles lighting effects - hold it down and it'll turn off the LEDs - you should hten be able to control them through software.
    Took me a good while to work it out as there is no manual covering this area....
