Salutations sports arena,
I've come here for some advice or even your thoughts on negative reps. So here's my situations/current way of thinking:
I go to the gym with my housemate, we do the same routine and on our last sets we usually end up giving each other some slight assistance. Recently I've decided to start pushing myself a little further in terms of adding weight more frequently with my exercises; for instance on the bench press I've been stuck around 80KG for my final set for about a month now so last week I added 5KG pushing me up to 85KG for my last set then earlier this week I added another 5KG making my final set 90KG. On my last set I aim for 6 - 8 reps now in the past my last two or three reps need a little assistance but since I've started moving the weight up I seem to need assistance throughout all my reps. What I mean by assistance is this, I take the bar from the rack without any issues and lower it to touch my chest, I then get about 10cm from my chest putting my arms at a 90 degree angle; my arms tend to lock at this point and I need a little help getting past this so my housemate will put his hands flat under the bar in-between my grip and slowly add a little pressure to push me through the locked position where I can happily get the full extension on my own. However I'm just wondering if this is a wise choice since now I need help on all my reps, My train of thought is sooner or later I'm going to hit a point where I just can't lift it maybe in a week or two's time when I've added an extra 10KG if I keep this up will it mean by that time when I get to 90KG where I need help now, In two or more weeks will I be able to lift this without the need of assistance? Or am I best just dropping the weight and scrapping the assistance all together?
regards -Skeng
Edit: I forgot to mention I don't get as much of a "burn" when I get the assistance this is what has gotten me thinking that maybe I'm just cheating my way through it with the assistance.
regards -Skeng
