OcUK Staff
Yes correct!!!!
but what im trying to get at is even in fixed mode you'll get the spikes, example if your aiming for 1.40-1.425v u would need to set the vcore to about 1.5-1.525v if your using LLC on low or medium so going from load to idle u could see spikes of 1.45-1.475v which isn't good.With LLC at low to medium though yuo are followig Intels recomended voltage droop under load. They want this droop to occur to take into account for these spikes and protect the chip as its loaded. LLC at reg or medium is all that should be used when clocking for 24/7.
i think that for IB??OK - what about Skew Driving Voltage??
And the 1.38 volts max?? I've read elsewhere Intel say 1.52 volts as long as the chips stay around 70 degrees....
8 Pack I was reading this thread with interest (Gene V + 3770k) - some great tips there - I was particularly interested in your comments re Vcore and LLC
my 3770k (rubbish one) - needs 1.32V @ LLC V. high
and 1.355V @LLC High (1.32V after droop)
not sure what is worse for the chip?
thanks
Ah man! i think i have 4.6 stable and am pushing for 4.7 but i just can't get it stable...
So far i'm at
CPU Voltage - 1.425
Ram 1.5
VCCSA 1.1
VCCIO 1.0
CPU PLL 1.5
Prime just keeps throwing up errors...
4.6 seemed to be stable way back at 1.39 volts
I'm also getting near the limit of my cooler - 73 degrees...any ideas 8 Pack?
to be honest i've tried all different sorts of settings this afternoon and got nowhere. i think i'm gonna setting for 4.6 and get that locked down with as few volts as possible.
Bit of a shame as i had hopes for 4.8, and my previous chip a i5 750 did 4ghz (which in my mind was something pretty special)
4.6 in my books is distinctly middle of the class
