Help please
21 Nov 2020
I am having some issues with my Activision account for playing call of duty warzone, I have tried to contact customer support on several different forums and have had no reply. I have recently bought a new PC for gaming. I bought what I thought was a good pc second had as I could not afford the system new.
MB: MSI Z390 pro carbon
CPU : I9 9900k
GPU: MSI GTX 1080 TI
RAM: 32 GB Corsair vengeance 3200
CASE: Asus rog Strix Helios
the system runs fine and plays games brilliant with FPS well over 100 on most the games I play.
However the second I wired my new system up and tried to log in to warzone my account got banned. I have created a new account and that was instantly banned and I never even got to play the game, I logged in on a friends account played one game and that account got disconnected from server and banned. I've played the game for over 12 months on my old system without any issues, could anyone offer me some advice as what to do? I've tried every contact for Activision with no reply
You say your pc is second hand? Did you do a fresh install of Windows and all software etc? If not, sounds like there's probably some old cheat software on your system that's caused the ban. Really no other reason you'd get bans like this otherwise.
thank you for the reply
I have not tried that yet, the system was set up as new when I bought it but not sure if it was a fresh install of windows? it was mt next port of call. I've been reading on some forums that it might be a hardware ban but not sure if that's something that can be done or not, or if there is anyway to get around it without changing components.
kind regards
do you know if the ban will just be from the warzone servers or if i will be banned from all activision games ? was going to buy cold war but scared it wont work now
Not sure but I wouldn't buy anything untill you find out .
My assumption would be that if you need your account to acess another server then yes you would be banned .
Others may have more insight or ask on the Activision site.
