Help POWER SUPPLY ati 1950pro AGP
24 Sep 2006
hi there
iv just installed the ati 1950 pro
i know i my power supply is to small. but i dindt know this before i bought the product. im a bit tight on cash at the moment.
id like to know what the cheapest power supply would be to get hold of that will cater 30amps on a 12v rail. or what would be your suggestion for about £50
thank in advance
semi-pro waster said:
Welcome to the forums, I'd probably suggest an Akasa 460w as I think it is about as good as you will get for the money. If you want to go up to ~£60 then the OCZ Modstream 520w is worth a look also. :)
Ditto, not bad PSU's those for the prices, and should handle the x1950rpo fine. :)
thank you guys for the quick reply
can i also ask if this will be fine to connect to the motherboard, HD etc i quite new to overclocking + someone mention hiper to me waht you think
thanks
Hipers have got a bad rep for going boom so i wouldn't trust em, theres another one gone boom here
Will connect fine either of those, oh and welcome to the forums btw. :)
