Help Upgrading
8 Dec 2020
Hi All,
I need a bit of advise i do not want to built a whole new pc. I play a lot a warzone and cold war no other games.
asrock z77 extreme4
Inter I3 - 3240
650W PSU
GTX 1060TI - Was thinking to buy or is there any other gpu for around £150-£200 budget that are better.
I was thinking just to just to upgrade my cpu to a i7 3770k. Would that be ok?
6 Jun 2008
Finland
That's really problematic to upgrade for current games.
Any CPU you could fit to that board makes sense only with pocket money budget:
Those quad cores are simply less than half of the CPU power of new consoles.
