REVIEW HERE
We have a huge shipment of Morpheus coolers about to land any day now!
Raijintek Morpheus High Performance VGA Cooler @ £44.99 inc VAT
Morpheus, a superior high-end VGA cooler is designed to meet cooling requirements of upto 360 Watt TDP. Additionally, Morpheus comes with 24 ram heat sinks & 1 big VRM heatsink. Morpheus is a Multi -Compatible with most modern nVidia (Kepler) and AMD Gpu's (Hawaii & Curacao)
Compatibility:-
- AMD: Hawaii Chip (R9 290x/290, R9 270x/270) Curacao Chip (HD 7850, 7870 xt)
- nVidia Kepler Chip (GTX 650, 660, 660Ti, 680, 760, 760, 770, 780)
Features:-
- Cooling Capacity 360 watts TDP
- 12 pcs copper heat pipers and 129 fins for efficient heat dissipation
- 24 pcs heat-sink for RAM & 1 heat-sink for VRM
- Thermal adhesive to lower RAM and VRM temperatue significantly and assure proper bond.
- Supports 2 x 120mm Fan
Technical Specifications:-
- Dimension (WxDxH) 254x98x44 mm
- Weight 515g
Only £44.99 inc VAT.
ORDER NOW
Regardless of its limitations, the Morpheus is hard to ignore if you’re the owner of a graphics card that sports a reference cooler. For a street price of £45 plus the cost of a couple of 120mm fans, which is considerably cheaper than water-cooled equivalents, the Morpheus could revitalise a hot and noisy graphics card and even free up some further overclocking potential.
Compatibility:-
Features:-
- Weight 515g
ORDER NOW
