31 May 2010 at 11:33 #1 MoBo MoBo Associate Joined 23 Oct 2002 Posts 786 Location Norwich Hi all, What is the best way to connect my iphone to my Musical Fidelity A3.2 amp? Thanks
31 May 2010 at 12:09 #2 branddaly branddaly Associate Joined 25 Nov 2004 Posts 1,872 Location Manchester Uk Super glue. Oh OK, 3.5mm to phono cable.
31 May 2010 at 12:13 #3 probedb probedb Associate Joined 24 Jun 2006 Posts 1,462 Get a line out cable or a dock that provides that functionality. Super glue would work too but you'd get no sound.
31 May 2010 at 12:27 #4 MoBo MoBo Associate OP Joined 23 Oct 2002 Posts 786 Location Norwich branddaly said: Super glue. Ha ha ha ha HA Oh OK, 3.5mm to phono cable. Click to expand...
31 May 2010 at 12:57 #5 Martynt74 Martynt74 Soldato Joined 20 Feb 2004 Posts 23,757 Location Hondon de las Nieves, Spain I'd try and get a dock as it has other advantages such as charging etc whilst you're using it. There are plenty budget ones out there.
31 May 2010 at 22:25 #6 MoBo MoBo Associate OP Joined 23 Oct 2002 Posts 786 Location Norwich What is a good dock for £100?
1 Jun 2010 at 14:51 #7 Dazza_Random Dazza_Random Associate Joined 14 Sep 2007 Posts 302 branddaly said: Super glue. Oh OK, 3.5mm to phono cable. Click to expand... lol just lol ...
1 Jun 2010 at 15:54 #8 Seft Seft Soldato Joined 18 Sep 2003 Posts 4,104 Location Radlett Wadia sell a dock that provides a digital out for the iPhone, allowing you to bypass its DAC.
